Application:1989-1998 NISSAN 240SX
White Bunny? The "White Bunny Special" was first created by realising that KA24 engines come stock with a 225mm clutch surface area, but using parts from other Nissans will allow one to run a 250mm clutch, which by logic gives more area for the clutch to grab onto thus reducing the chance of slippage.
The Competition Clutch Stage 2 - Street Series 2100 Clutch Kit provides approximately 80% increase in torque capacity and is properly suited for aggressive street use and moderate track use. The Carbon Kevlar material with its alloy backing matched to a performance pressure plate will provide smooth engagement and extended life. A 500-mile break-in is highly recommended with this set-up.
The 2100 Series kit includes a performance pressure plate, a high torque sprung disc with antiburst steel backed Carbon Kevlar facings, all applicable bearings, and the appropriate alignment tool.
Includes:
Pressure plate
Clutch disc
Pilot bearing
Alignment tool
Flywheel
Priced at $338 USD with free shipping across the USA!
Contact us today to order yours!
[email protected]
