You will need an Auto Ecu, look in the classifieds section under Complete Part-Outs, a lot of people should have one.
Rear end gears should be the same, no worries.
The automatic trans should have longer gearing as its only a 4 speed (including OD) vs the 5 speed manual, so your engine may run a little higher in rpm @ cruising, hence the 1 mpg difference in gas mileage.
Anyone feel free to chime in to shed some light if I missed anything
