Unnatural1 »
https://forums.nicoclub.com/unnatural1-u59065.html
Fri Oct 03, 2008 2:30 pm
I work at a local independent shop and we are a Valvoline dealer. We received some info regarding Mercon V being a suitable replacement for most all other ATF's, save for a few exceptions such as CVT's and the occasional German transmission.
Valvoline claimed that their research has shown Mercon V (which is the same product you linked to) is recommend to replace just about everything out there. My first thought was "I don't know about this." But, then again, most synthetic oil makers, Amsoil, Royal Purple, etc..., use a "one fluid fits all" approach to their product lines. Redline on the other hand has a couple of different fluids but they are still covering many different manufacturers with one fluid.
Right now I'm running regular Valvoline Dexron III w/ red Lube Gard in my Q. When I change it again I'm going to probably go with Amsoil ATF (we have an Amsoil dealer next door). I'm lucky to have an ATF exchange machine at work too. So fluid changes are easy!
Modified by Unnatural1 at 12:42 PM 10/5/2008
