Nismo_Freak »
https://forums.nicoclub.com/nismo-freak-u248.html
Fri Sep 19, 2003 10:57 am
It's an OBDII engine, meaning it has alot more sensors for one including the secondary 02 sensor which your exhaust system is not bunged for.
Secondly, you will have to re-wire you ancilleries such as your wipers because they are different on the S14.
Like I said before, just because it's 5-lug does not mean it has an LSD. You need to verify that it has one, check for an orange dot above the diff. fill hole, OR... you can jack up the rear end of the car and spin one wheel forward. The other wheel should move the same direction.
