defrag010 wrote:Awesome pics! did you get any pictutres of his machines? Also, that H-beam rod in the messed up pic was probably a custom made one, eh.
Nah sorry man I posted up all the best pics we took. He had a huge boring machine, some valve seat machines etc... not really sure, because I don't know much about machining & head work I didn't pay much attention to his actual equipment... but I do remember seeing at least 4-5 main machines that would be frequently used, then he had rooms off to the side with more stuff in them (flowbench, engine dyno etc). I do remember seeing a big rack of different boring, honing, dremel & other bits tho.
We neglected to photograph a VH41 on a stand in one of the side rooms under a cover, which had a massive alloy plate built in to a wicked custom sump setup... dammit! The plate was there to bolt the external oil pumps to etc.
elwesso wrote:I think i had a brain fart about the US 41 vs JDM 41 heads....
remember the later 94 45 heads had the oval ports... I wonder if that would make them nearly identical to the 41?
Eheh... yeah if the VH45 oval ports are the same dimensions, then the heads would flow more or less identically. The only real differences are in the casting of the heads with regard to the front covers etc.
One myth I think we've successfully laid to rest is the one where people think the VH45 is physically larger than the VH41, it isn't. They're exactly the same size, it's just an optical illusion caused by the wider front covers on the 45, and the VTC solenoids being on the front of the intake cams rather than feeding in through the side of the heads like on the VH41.
Another myth laid to rest is that of VH41s apparently not having VTC... they do. As you can see in the pics, the little hexagonal shaped bit screwed into the side of the JDM VH41 head at the front is in fact a VTC solenoid valve. Also note that the US VH41 head has the tapped hole for VTC solenoids too. The oil feed for the VTC drums on the ends of the intake cams are obviously just relocated.
