Bronze MFP wrote:rb25 turbine blades are ceramic, the compressor blades are some sort of high strenght plastic IIRC
i thought the z31 turbo was water cooled as well, anyone know for sure?
84-87(?) are water-cooled I believe. After that they are T25's. The pre 84's had the same T3, but are oil "cooled" only I think.
Edit: And what you guys have said about both turbos is pretty accurate as far as I know. If it were a longterm choice, I'd probably get the Z31 because while it'll sacrifice some spool, it's actually made out of metal, rebuildable, and seeing as it's been around a lot longer there's more support/mods for it available.
