Axoure Dragonkin »
https://forums.nicoclub.com/axoure-dragonkin-u19649.html
Sun Jan 09, 2005 12:21 pm
sr20det goes right in ~2000 for motorca18det goes right in ~1200 for motorrb20det needs special mounts and a couple of things ~1200 for motorrb25det needs special mounts "" "" """ ~haven't priced themrb26dett needs special mounts and a bit of custom work ~3500 for motor
sr20's and rb26's are more expensive because of high demand, but all of these choices have advantages and disadvantages
i'm leaving out the crazy swaps, because you asked for relative ease
when i say "goes right in" those are the one that will bolt in just fine, all of these will still require some components from USDM cars, but seeing as you have a 92, you should be covered, unless it's auto, then you will need clutch parts which is easy enough to do as well
somebody correct me if i'm wrong
