To start, the KA24DE is stock. It is the s13 KA24de with the butterfly valves in the intake. Has NGK wires, new NGK plugs, EGR delete. Things I've changed are injector o-rings, thermostat and gasket, hoses, belts, front/rear mains, valve cover gasket, oil, oil and fuel filters, etc. Swapped into it a clean gas tank and fuel pump. Using automatic ECU (green number 29)
The car will run, idle at 750/800rpm in limp mode with the maf unplugged. As soon as the maf is plugged in, it will jump up to about 2000 rpm and subsequently sputter and die within 3 or 4 seconds.
I have followed everything per FSM in the EC section
ECU reads code 55 - normal operation
I have swapped ECU's. Same problem.
TPS ---- pg 121 of EC
Ohms good for sensor
Voltage good
To ECU has continuity
Coolant Temp Sensor pg 99
Ohms good (Sensor)
Voltage good
Ground good
To ECU good
MAF pg 96
Ohms good (Sensor)
To ECU good
Voltage signal readings good both with key on/engine off and running
Dizzy pg 93
To ECU good
Injectors click
When disconnecting, hear relay click on passenger side
Voltage good when spun
IACV
Removed and cleaned it (the body as well as the valve that's held on by two screws)
Ohms good
Injector resistance is normal
Power Balance Test – seemed like momentary loss of power as per FSM
Compression Test – good and even across all cylinders
Fuel Pressure – good
Timing – good (20 degrees)
Vacuum leak test – good (I made a tester that is attached to the intake pipe and connects to air compressor)
FPR w/wo vacuum – no difference
New injector O-rings
I have extra parts laying around, and swapped them just for the hell of it.
I have swapped mafs, no difference
TPS, and manually controlled with a screwdriver, no difference
knock sensor, no difference
ECU, no difference
