Common Mods for a 720?
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
nissannut1992
Car: 1985 Nissan 720 4x4 King Cab
hello
What are some common/must have type mods that can be done to my 720?
thanks
PEZi
well... up top there might be a little info in the stickies.... but basically the 'have to have' mods are a custom exhaust and a weber carb
nissannut1992
well I gotta Weber Carb, Magnaflow Exhaust and Flowmaster Muffler. Sounds like there ain't much else I can do.
PEZi
well you have a 4X4
try something no one else has done (or at least out of the norm) and see how it goes!
for example... i made a 2wd race truck.... not many of those out there
see what fits you and take it from there!
dogred
Car: 1983 D720
PEZi720 you forgot to mention spark plugs. I use E3's.
PEZi
ah true... i got Pulstars
nissannut1992
I usually go with NGK's. But I really don't know what's best.
Aven
Car: 84 720 Kingcab
What are the benefits of changing out the stock for a Weber, other than the Weber is probably cheaper than going to the dealer for a new carb?
dogred
Car: 1983 D720
Well Pulstars usually run $50 a pair. (correct me if I am wrong)
A full set of E3's will run you around $50 (8 plugs).
A full set of single platinum NGK's will run you around $25.
All three of these will get you more performance.
I know from personal experiance with multiple cars E3's increased the HP and MPG from the install. Also I have not recieved any negative feedback from any of the customers that I recommended them to.
Some of the best upgrades are the ones you create yourself. I am thinking of taking some fender flares off a Pathfinder to see how they look on my 2wd truck.
PEZi
Aven wrote:What are the benefits of changing out the stock for a Weber, other than the Weber is probably cheaper than going to the dealer for a new carb?
its easier to work on and offers better performance
dogred wrote:Well Pulstars usually run $50 a pair. (correct me if I am wrong)
yup.... they're a bit pricey.... $200 for all 8... if you can find a deal on them like i did than i'd say its worth it though.... deals come and go... just gotta look for 'em
they offer slight performance over E3 (not noticeable) but they have a warranty to last longer than E3's (i'm not 100% sure on this)
86 720
Car: 1986 720 4cyl Standard Cab
You can do a headlight swap to HID and cluster overlay.
nissannut1992
who manufactures the E3's?
dogred
Car: 1983 D720
http://www.e3sparkplugs.com/buy-auto.htm
I believe they are an independant company and their waranty last 100,000 miles.
PEZi
just a heads-up on spark plugs... we have a sponsor here on NICO (sparkplugs.com) who give a NICO discount
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Have any of you guys tried changing the coils. Haven't gotten mine back yet but I used two MSD blaster coils so I can't say if there is an improvement in power.
dogred
Car: 1983 D720
flinterman2000 wrote:Have any of you guys tried changing the coils. Haven't gotten mine back yet but I used two MSD blaster coils so I can't say if there is an improvement in power.
Like to know if they make a difference.
flinterman2000
Will add pics with the post.
mcrdpisc2086
Car: 1984 Datsun/Nissan 720
well you could always think about a turbo, i actually droped a ka24 in my '84 720 out of a 93 240sx and dropped a turbo on it. a small garrett 22/24 but its worth it. i like the z24 but it carburated, i just did a change and went to fuel injection. im currently building an sas. dana axles.
dogred
Car: 1983 D720
I put in a Accel yellow coil on the intake side, no real noticeable difference that I can tell.
flinterman2000
Had two Accel silver street coils on my Z20. Noticed somewhat quicker revving but same max rpm.
Return to “Datsun 720”
