common engine temperature question
uvamosk
So, I installed a temp gauge and now im trying to figure out what i should be looking for.
It has been riding around 169f or 70c ish... It seems to stay there maybe a little lower while driving.
when i am sitting and some times while moving slow it will go up to 80,85c which is something like 180f to 190f
I wanted to know if thats ok or notI think the fan I have just isnt strong enough to keep the temp down.
I have 2" alum radaitor and stuff just used a junk yard fan though.. I set it to come on around 160f or so
thanks guys
uvamosk
Bump
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
I would have to agree with you about the undersize fan. At idle or low speeds, where a fan is critical, the coolant temperature should be around 170 F. If you don't have a fan shroud, I would suggest installing one otherwise go with a larger fan.
