StarPD »
https://forums.nicoclub.com/starpd-u54244.html
Sun Mar 11, 2007 11:58 am
Older G50s and new F50s may have oil consumption issues. Many Q45 owners use synthetic motor oil.
For those who aren't aware of it, synthetic oil does not produce blue smoke like conventional motor oils do when it burns. Accordingly, we cannot trust keeping an eye out for the tell-tale blue exhaust smoke that results from worn valve guides/seals, or worn or improperly seated piston rings.
Also, synthetic oil can seep past seals and gaskets easier than conventional oils can.
Many of us are aware of this, but some younger, and even older members may not be.
This is why especially if you use synthetic motor oil, you should make it a habit to check your oil level frequently.
Of course, while you're at it, might as well check your transmission fluid, coolant, and brake fluid, as well as visually inspect your belts and hoses and tire pressures. Remember the old adage about "***-U-ME" ing everything is okay, just because it SEEMS to run fine. Surprises are usually expensive, as a number of posts in this forum can attest to.
