comment on my setup idea?
josephg15
Car: 1992 240sx
so i plan on having this as my setup in the next 3 weeks...
redtop boosting 10psi - 12psi (not sure yet) with:
stock t25 turbowalbro 255hks 256 camsebay fmicnismo fprz32 mafchipped ecumegan 3" down pipe and test pipe3" hks super dragger catback turbo xs dual stage boost controller
what do you guys think? would i need the z32 maf? do i need injectors? im not upgrading the turbo yet because i just got this t25 rebuilt....stupid me...but any way let me in on some of your input...thanks
Modified by josephg15 at 7:21 PM 8/16/2007
josephg15
Car: 1992 240sx
anything?
SpeedRacer1
Car: 1990 240SX, G35
The stock injectors and MAFS should be able to handle 12 psi. If you upgrade the turbo then you will need new injectors, MAFS, retune on the ECU, etc.
Is your current ECU tuned for the cams?
chicos240
Car: 1995 240 SX
<threadjack>Speedracer1... do you have a FAST write up. I can seem to get mine to work correctly</threadjack>
josephg15
Car: 1992 240sx
no my current ecu is not tuned... its stock, because i am at stock boost right now...so your saying if i get the 256 cam and tune my ecu, i dont need bigger injectors and i dont need a z32 maf...i just need the ecu tuned for 12psi right?
Fast write up? are you asking me?
Hijacker
Car: '92 240sx Convertible
'94 F-150
you don't really tune ecus based on a specific boost. i run a stock ecu and run 13ish psi off the t25.
however, a set of cams will upset the idle and move the powerband around. the stock fuel map is based on where the stock cams place the power band.
chicos240
Car: 1995 240 SX
No man...I was asking SpeedRacer1
But you are correct in your understanding of his response.You should be ok with the current injectors and stock MAF.If you are going to upgrade everything, make sure you let whomever is tuning your ecu now EVERYTHING you are adding on.
SpeedRacer1
chicos240 wrote:<threadjack>Speedracer1... do you have a FAST write up. I can seem to get mine to work correctly</threadjack>
Email me with what program you have, how you tried to install it on your comp etc, there is a step or two thats not really given to people.
[email protected]
josephg15
Car: 1992 240sx
so if i just get the 256 cams do i need to tune my ecu?
SpeedRacer1
No, but to get the best potential out of your cams you should have something compensate for them. You can run them with a stock ECU, you may want to get adjustable cam gears as well.
josephg15
Car: 1992 240sx
what do i need cam gears for? what kind of power would i get from the cams alone, no tuned ecu
zee1121
Car: 1992 nissan silva
you should go with the 10psi
SpeedRacer1
Cam gears are to help better tune the cam timing, along with ignition timing and the ECU tuning you would net the absolute best results. But you would need to get the car on a dyno to get any real results.
josephg15
Car: 1992 240sx
speedracer1...its sounds like you know quite abit about the sr20...i am having a problem deciding what i should do about my next upgrade...im thinking 256 cams or 264 cams. what do you think...i dont want to get a t28 yet. what do you suggest?
SpeedRacer1
I'm not going to tell you what to get, you need to do research and find what cams are best for you. You'll want to get cams with the same amount of duration but if you can figure out whether its better or not to get cams with staggered lift is all something to take into consideration.
Though 256 ~11.5mm lift should be good enough for any of your hp requirements, it is up to you with what you want to do with the car ie: power, streetability, emissions concerns.
josephg15
Car: 1992 240sx
ok cool...one more question...i can run the 256 cams with out chipping the ecu, right?
SpeedRacer1
SpeedRacer1 wrote:You can run them with a stock ECU
