- I think I will do this. I was thinking about it last night, I think I'm gonna save up for 550's/Z32, and an enthalpy tune.biggie wrote:Just some thoughts.
- If you are spending the money to build the engine, why not get a tune of some sort? Basically I'd wait until you save for everything for the injectors/maf/tune. Don't rush it and take the chance of messing up a rebuilt engine.
- T25 is really too small for a KA, T28 would be the smallest I'd put on.
My thoughts exactly, you've got an engine there thats built for armageddon, why only throw a T25 at it? With the lower compression, you're going to get less power per psi of boost anyway, so it'll actually make less power than a stock KA with a T25. You've already spent most of the money, just finish it off rightbiggie wrote:Just some thoughts.
As I said, the T25 is what I have right now. So I'm going to run it for the time being. I plan to upgrade my turbo to a T28, or even a T3/T4 top mount setup, eventually. I wouldn't even have to change anything, since enthalpy tunes off of maf/injectors. I'm getting 550's and a Z32 maf, I'm sure I'll have room for upgrade.SX APPEAL wrote:My thoughts exactly, you've got an engine there thats built for armageddon, why only throw a T25 at it? With the lower compression, you're going to get less power per psi of boost anyway, so it'll actually make less power than a stock KA with a T25. You've already spent most of the money, just finish it off rightbiggie wrote:Just some thoughts.
