Hi,
I just wanted to clear something up. First of all, please go to the Cometic website at
http://www.cometic.com/sportcompact.aspx.
Under "Select Make",
select Nissan
and under "Choose Engine"
select "SR20DE/DET 91-96 DOHC 16V 2.0L (W/ VVL) 1 int. oil hole" -please note the "1 int. oil hole" part.
Picture of the SR20DET w/ vvl (1 int oil hole) from cometic site. (below)
Picture of the SR20DET w/o vvl (2 int oil hole) from cometic site. (below)Note Bottom Left of Picture: w/ VVL has one hole, w/o has two. (incorrect)
As you can see, according to the cometic catalog they intended to have only 1 oil hole for SR20DET w/ VVL. This is wrong because SR20DET w/ vvl requires 2 oil hole while the SR20DET non vvl will work with 1 or 2. As an authorized Cometic Dealer, we will make sure to relay this very important information to them so they can get this issue fixed at once.
The shop that you bought the Cometic gasket from gave you the one according to the advertised specs, so this is not their fault. This looks like something that Cometic needs to clear up.
And most important:*****************If you purchased this Cometic Head Gasket from FRSport.com, please email, or call us during normal business hour at your convenience, and we will make sure that you get taken cared of.*****************
Good Luck,FRSport.com Team
