Does that sticky from 2005 about Cometic MLS headgaskets being problematic still hold true? According to this,
zerothread?id=477587, it is not actually true anymore... a little confusing. If Cometic MLS HGs are actually fine, maybe the sticky could use an update with an explanation and emphasis on the right block preparations, maybe some newbies still read that...
- HG bore size (still Cometic)... I can't really make sense of the bore sizes, the standalone headgasket is specified as having a 85mm bore, but the one in the top end gasket kit specifies a 84mm. Is that it? If I order the kit, I get the 84mm one, if the standalone, I get the 85mm one? Any experience?
