extreme135 »
https://forums.nicoclub.com/extreme135-u47620.html
Fri May 11, 2007 11:31 am
I just put my cometic gasket on for the second time, my first build I did not use any copper spray on it just the gasket with the head,front cover and block decked, tightened the headdown with arp studs to 75LBS. after running the engine for about 30 seconds, oil started leaking out the exhaust side of the head some, but after running the engine for about 30 min. it stopped completly, my second build with the same gasket I sprayed it with copper spray and torqued the head to 80ft.lbs., did not have any leaks at all. But both times had the block, head and front timing chain cover decked and surfaced, if it is not clean level with a polished looking finish, you likely will have problems, because it is metal, I have heard of guys block sanding the head and block and getting away with, but i would not personally, what do you have it torqued down to, you might fix your problem by torqueing the head down some more.
