I was driving down the road at night and my cluster lighting was fine then all of a sudden it flickered turned off came back on a second later and then stayed off. I started messing with the light switch that has the 0-1-2 positions 2 being night lights on. When I would switch it to position 1 the cluster light would work but obviously my headlights are off in that position. After a minute they just stopped working overall.
I have attempted to repair the problem by taking the cluster out unplugging everything and checking the 3 bulbs. All bulbs are fine apparently I am not getting any power to just the 3 illumination lights. The Cluster works fine. Even the small warning lights work like check engine,brake,turn signal etc . I unplugged and replugged the dimmer switch. Unplugged and replugged the combination light switch as well. I also checking all the fuses on the driver side kick panel. Everything is fine and I am left puzzled. I found a weird box which I think is a relay wired from the Dimmer switch I am not sure if that is original. Below are some pics. Anyone with any advice would be greatly appreciated. This is really getting to me. I love my 240sx and like to keep it babied and in perfect working order. Thanks in advance!
Lights off
Lights on
http://youtu.be/1XuYZMOz-Ao
