Combination flasher unit
tgunz
For 04 pathfiner, where's the combination flasher unit? I searched here and the service manual pdf but without much luck. It's not one of those three relays that I see above the inside fuse box is it? Those have markings that says they have 5 terminals, but the manual shows the flahser unit only has 3.
Qxxx4
Car: 1999.5 Infiniti QX4
2012 Ford Mustang
it might be on your relay box under the hood...those all have 3 prongs...theres a fuse box and a seperate relay box under the hood (at least in 97-00)
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
On an '01 PF, it's up above the driver's left knee, way up in there, if I recallcorrectly.
tgunz
Chuck Tribolet wrote:On an '01 PF, it's up above the driver's left knee, way up in there, if I recallcorrectly.
Do you mean behind the coin holder? That's where I'm talking about too. There's a whole bunch of fuses, and three relays there. But like I said I'm not sure if those are it because they seems to be the 5 pins ones and the flasher is suppose to be 3 pins only, as far as I know.
tgunz
Qxxx4 wrote:it might be on your relay box under the hood...those all have 3 prongs...theres a fuse box and a seperate relay box under the hood (at least in 97-00)
Yeah I looked @ the lables on the cover and don't see one that says flasher, turn signal, or something equivalent.
Chuck Tribolet
'87 Chevy Corvette
There are six relays, at least on my '01. The top three are out of sight unlessyou look real carefully. I forget where the flasher was, but it was definitelyup in there some where (It's not there any more, I replaced it with a louder onethat I put out in the open.).
My '01 PF service manual shows it, in the back of the Electical section, underElectrical Units Location. Note that this is a picture, not text, so Ctrl-F inAcrobat won't find it.
tgunz
Ah yes I see it on pg EL-480. Thanks for the pointer.
