Color Code on Pathfiner
nissan 01
Car: 01 Nissan Pathfinder LE
2001 PAthfinder LE Production us 12/2000
color code on the firewall says KYO....but my car is a dark brown. KYO was silver it says on some website....
i'm trying to find some touchup paint for some minor scratch.....i've seen duplicolor has something called brush pewter...is that the color of my car?
my car is not silver not gold....its like a dark brownish color....please let me know thanks
Pwnin O'Brien
It's not possible that your vehicle has color code KY0, that color was only available for 2002-2004 Pathfinders. That color is chrome silver, my Pathfinder is color code KY0, here's a pic...
Pwnin O'Brien
Are you sure it wasn't KX0? That is a bronzed gray color, that seems closer to your color description. You should probably double check your placard, I'm sure you just read it incorrectly.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
CY0 = BROWN PM (pearl metallic)
nissan 01
ill re-read it later today. def not a C...it def starts with a K but thanks i just neeed some touch up paint to put on some areas....all the kragen doesn't ahve any duplicor ones so i might need to order online.
Pwnin O'Brien
I got my touch up paint from the dealer, it's pretty cheap for a small ball-point tube of it and it's guaranteed to match your cars color.
Kidastra
Car: 2003 Nissan Pathfiner
KY2 is pewter, which is somewhat of a brown color
QX4ME
Car: 02 Infiniti QX4 4WD
11 MB C300 Sports
06 Honda Odyssey
Edmunds lists all colors on 2001 Pathfinder:
Aspen White Pearlglow, Bayshore Blue Metallic Bronzed Gray Clearcoat IO Metallic, Burnt Cherry Clearcoat Pearl Crimson Blaze Red, Sahara Beige Metallic Sherwood Green Pearl, Sierra Silver Metallic Super Black
If there is nothing close to brown you described, could it be a custom paint? What is the fire wall color?
Pwnin O'Brien
lino wrote:CY0 = BROWN PM (pearl metallic)
CY0 paint code was only available for 2003-2004 Pathfinders.
Pwnin O'Brien
Kidastra wrote:KY2 is pewter, which is somewhat of a brown color
KY2 paint code was only available on 2003-2004 Pathfinders.
nissan 01
http://sfbay.craigslist.org/sb....html
my car is that color......but its a 2001..maybe it got repainted? let me know!!!!thanks
Pwnin O'Brien
nissan 01 wrote:http://sfbay.craigslist.org/sb....html
That's KX0 (bronzed gray). Weird thing is that color was only supposed to be on 1998-2001 Pathfinders, but it's on newer ones as well (like in the picture). What's more weird is the fact that before 2002, the bronze gray color looks a lot more silver than 2002-2004 bronzed gray. They are completely different colors.
nissan 01
thanks seems like duplicolor doesn't make that touch up paint...guess i got to go OEM....unless someone else knows of any?
