Collected info for a RB20DET into S13
zmannz
Car: 89 s13 coupe- track car
92 s13 coupe- dd
Pin 43 will wire in through the dash plug, that sends your signals to and from the dash and ignition IIRC. I think it matches to the orange wire in the dash plug. Pin 45, I believe that runs from up near the battery tray area, either in the grey or brown plug that connects on the fuse box connectors.
The inj grounds, you say they are hot does that mean hot to the touch? Maybe sticking injectors or a bad ground elsewhere is overworking these wires.
lexrob
Car: s14 95'
Just to clarify. 43 to dash plug is correct-45" also connects to dash plug
I am still unclear with the eccs and ing. coil relay wiring. Power does not just go from f3 to eccs plug it go's up and down harness FACTORY connections.
If you read all the guides and look at the wiring diagrams everything is almost to the "T". With the theory that the ecu grounds the relays switching them both on upon ignition signal. To include fuel pump? This is done by the drivers.....
I think im correct maybe someone can keep that going. I have just traced every single wire and looked at and verified every source over a wk. I cant afford to toast another eccs.
HEADs up guys *some of the wiring schematics differ slightly i found 3 diff. ones* some leave crap out but the rb20det shop manuals is by far the best kind of big tho.
lexrob
Car: s14 95'
did anyone on here not send out there harness and seriously do it themselves??? I honestly dont believe its possible.....the information is not out there.
if it is and you think im wrong. give me a link of diagram on how to wire in the ing. coil, and eccs relays. .....please
RustspecS13
Car: '74 260z and '88 300zx turbo
I wired in my s13 myself and it worked perfectly. I kinda looked at an s14s wiring and its a little more involved, but its doable. Just make sure you solder everything. Its definitely possible because on the s13 its like 12 wires, and barely more for an s14.
I have a link some where to a bunch of saved files from race bread. I just have to find it. Its got good s14 wiring in there some where....
~Alex
lexrob
Car: s14 95'
Please find it rust. Maybe im the only one doing s14 wiring right now. I really just cannot find any information what so ever.
Just to add from the factory pin 49,59 both have constant power along with injectors NOT Switched like the schematic shows! Please someone check that out maybe im just screwed.
Monogato
Car: 1989 Nissan 240SX SE
Can't seem to find a clear answer for this. So I'll ask here.
If I get McKinney mounts, I'll have to hammer the firewall.
If I get the R32 cross, I can use my stock mounts.
BUT will I still have to hammer the firewall, and has anyone had any hood clearance issue with the R32 cross member?
db_s13
Car: 92 VQ30DET 240sx
I have the r32 xmember and no hammering here
Monogato
Thank you, how does it sit?
hisoka
Car: jdm s13 rb20, onevia conversion yo~!
just sits kinda high, you gotta cut slits into the bonnet to close it
yotik
Car: 240sx Hatch
hisoka wrote:just sits kinda high, you gotta cut slits into the bonnet to close it
+1, sits high. i have my hood propped in the back for now. recirc, ic cold pipe, and timing belt cover hits.
thursdaymike
so after trying and trying i figured it out. r32 crossmember, rb20 motormounts, and the key i couldnt find anywhere, ka auto transmission crossmember. matched with a five speed driveshaft. no banging firewalls and cleared steering rack for me
putang29
Car: semi-sold 90 300zx n/a
2007 chevy avalanche
1990 infiniti m30 w/ rb20det
1995 240sx kouki w/ rb25det
http://forums.f31club.com/phpB...=3578
my 1990 infiniti m30 rb20det build, good stuff there
Monogato
putang29 wrote:http://forums.f31club.com/phpB...=3578
Looks good bro!
donut86
Car: '94 240sx Vert
I'm have a question about the wiring. I can't seem to figure out which white wire going to the fuse box to wire to the RB harness. none of the how-to's seem to have pics or details. any help?
HIGHFIV5
Car: 1989 240SX
zerothread?id=426543
This guide shows it.
The white purple (thick) whire on the 6 wire dash plug goes into that.Youll have to peal back the loom on the chassis harness (passenger side with the fuse box) and the white wires in there. Note there is 2...one is thick the other is reallly thick. You only want the thick one. Someone correct me if im wrong...
DoctorVroom
Car: 1989 Nissan 240sx
if i buy this i wont have to worry about the headaches of wiring do i?
http://www.240sxmotoring.com/ws-pre-mad ... 7AodBToAyw
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Yup bolt it in and get tech support too if you have any problems.
