Cone Junky »
https://forums.nicoclub.com/cone-junky-u86859.html
Fri Mar 07, 2008 6:39 am
It's actually a long story.In a nutshell- I've dropped from 1700 ppm when I bought it, down to 987 (limit is 799).
I have cleaned EGR ports, dropped timing from 24 to 13 BTDC, ran 2 fuel injection services (Seafoam and BG), cleaned corroded injector,MAF,and ECT sensor connectors, and replaced ECT sensor.
I am making progress, in fact I have finally passed the 25 MPH test, just failed the 15 MPH test. Between the colder plugs and fixing a small exhaust leak in front of the cat, I think I should finally get it to pass.
A new cat would probably solve it, but because the PO had the cat welded in, to upgrade to the exhaust I want I would need to replace the complete system (headers,cat, cat-back) it would run about $800-900. Money which I would much rather spend on some coilovers right now.
BTW- this is on an 89 240 fastback that I bought for $700. It's become a personal challenge to get this thing to pass without any large monetary investment. So far I am under $100, including $40 spent on 2 pre-tests.
