ks13 wrote:yea a part # would be great. Roughly what heat range does your plug translate to, a 7, 8 or 9?
through your reasearch what made the "extra turbo" racing plug less desirable?
The part number I have is DR12YS
The main driving factor for not using the extra turbo plug was the ignition system i use, i use capacitive discharge not inductive so the system benefits from a larger gap rather than a traditional smaller gap and dwell time relationship..
The turbo plug design i believe is aimed at reducing the rate of misfire on an inductive system through the tiered prong setup (3 small gaps, rather than one smallish gap), its similar in design to the bosch super4 spark plug, which I have used previously on a different engine setup...
According to the brisk data, the heat range "12" is two before the coldest, i don't know how this compares to ngk, bosch or other manufacturers, but as an educated assessment I would say it would be an ngk 9 by comparison looking at the data...
But I also have nitrous which does require a colder plug inherently..
hope this helps you
Modified by meminto at 11:59 PM 11/19/2009
