jdm_master_X »
https://forums.nicoclub.com/jdm-master-x-u30964.html
Sat Dec 09, 2006 1:58 pm
how quickly does your car warm up?
in cold climates engines tend to run a little richer to heighten the temperature of the engine to normal operation.
frozen fuel lines will cause tremendous hesitation upon warm up. i highly doubt your fuel pressure regulator froze up either.
im inclined to believe its your coolant temp sensor not effectively sending signals to the ECU for temp readings. an o2 sensor heats up internally, and the engine would run rich from the o2 because the engine is physically running lean.
