Cold weather and boost spiking??
meet07
Car: 89 180sx rb25det
For the last 3 days my car has been creeping up to 12lbs of boost and cutting out. I thought it was my boost controller but I removed it and ran the hose straight from the hot pipe to the wastegate. Took the car for a spin and it spiked again. I mean its been around 15-40 degrees here in Raleigh,NC but I didnt think that would cause an extra 5 psi. Is my wastegate defective?? I havnt meesed with it so it should not be bent or anything.
has anyone had this problem before??
Mods:-freddy intake-stock turbo-front mount-rfl bov-stock dp-3" exhaust-safc
Carryl
on average is 85degrees F here on my island and at night ...mid to high 70s. running off the waste gate i get 8psi during the day and creeps to 11 at night might be more dramatic here since i'm at sea level..
240z4u
Car: '95 Nissan 240SX
Whats your w/g location? my car used to creep during cold weather.
meet07
im running a factory wastegate with the factory turbo. When I had my turbo da9 b16 I would see maybe 2psi increase over the cooler weather but nothing this drastic. Could it be b/c of the smaller turbo or do I need to clean/lubricate something on the gate?? Its prett agravating
xX RB Xx
Car: SE3P, FC3S, FC3C.
its 100% normal, on colder days your going to have more psi because the air is denser. like right now im running 11 psi, and when its warm i run, well i really dont know because i havent had the car running during the warmer months. but i have friends that have boosted cars and they are running more boost when its cold.
meet07
Yeah I know that but an extra 5 psi??? That pretty much means the car is pointless to drive during the winter.
Carl H
what kind of boost controller are you using?if you say manual thats the problem right there.
Nissan2367
meet07 wrote:I thought it was my boost controller but I removed it and ran the hose straight from the hot pipe to the wastegate.
Did the same thing when the controller is not connected...
TECHLINE08
Car: RB S14
mine does the same things, everything stock, spikes to 12-13psi on cold weather, i say normal, doesnt cut out though
meet07
so should it boost past 12psi without it cutting out?? If so I need to look for boost leaks I guess. The temp over here in nc went up a lil and everything is back to normal. I was just stumped on the whole spiking issue. I guees the smaller turbo and toques causes it to spike more than my integra. But then again it had a external gate.
