Cold + Turn/Stop = Squeal
Neejay
I havent been able to see if it does it in the day time or not yet, but the last two nights when I got off from work (about 45 +/- degrees) at start up, after I stop and start accelerating, and when I turn theres this loud squeal like its a belt. I was thinking it was just cause its been colder than usual, but Im not too sure.
Its similar to Nismo31's problem, just a little different.
nyckanny
its the brakes, not the pad. but probably a caliper issue or rotor. loits of 240 brakes have that over time.
Neejay
nyckanny wrote:its the brakes, not the pad. but probably a caliper issue or rotor. loits of 240 brakes have that over time.
I switched my brakes to JDM 180sx brakes from a front clip this shop had. I got new pads (carbon + something else = no brake dust). I hope its not something BAD.
Damn...no wonder it disappears when I speed up. Thanks, I'll have them checked out.
EDIT: But it happens at start up...? No moving at all...
Anyone else wanna take a shot?
TakeNotes
Car: 1992 240SX SE, 1995 240SX SE
I get this too, if you check that one of the belts you'll see that they might be pretty well damaged. I was recommended to just replace the 3 belts and then the squealing would go away.
It's not the brakes since it happens when you come to a full stop/at start up... then simply goes away once you get moving.
Florida240sx
I get a squeal almost everytime I start my car up and it's under 70degrees. Lasts about 3 seconds. All my belts are fine. Been a year and they squealed last fall/winter also. think it's my AC
Neejay
Florida240sx wrote:I get a squeal almost everytime I start my car up and it's under 70degrees. Lasts about 3 seconds. All my belts are fine. Been a year and they squealed last fall/winter also. think it's my AC
How would it be the AC? And why does it only happen below certain temps?
benemorius
Car: s13, s13, eg, e36
It's your power steering belt. Tighten it; replace it if necessary.
Neejay
benemorius wrote:It's your power steering belt. Tighten it; replace it if necessary.
I just bought all three...might as well. Im having them put on in the morning, I'll come back here and update.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Might want to check your power steering fluid too. If it's low, then it'll make a loud, high-pitched noise too.
Neejay
Yep, it was just the belt(s). Changed, and no more squeal.
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
My car used to squeal relly bad last winter, it ended up being the alternator belt. It was so loose I could see it vibrating around... I can't believe it didnt fall off.
