mtnhighus »
https://forums.nicoclub.com/mtnhighus-u107812.html
Wed Jan 13, 2010 11:37 pm
the reason people recommend an oil change is it keeps whatever contaminates that may be in the old oil from dropping out and forming sludge in the oil pan. just cranking and letting the engine idle for a few minutes may not be enough to keep them suspended in the oil. coolant/antifreeze should be changed at a minimum of once a year regardless of climate or storage. and since you just moved from a warm climate to a colder one, probably be cheap insurance. oh, and how did the move go? what happened to the vespa?? and how did the cats do??
and some sta-bil is not a bad idea to add to the gas tank when storing for extented periods, helps keep the aromatics from evaporation out of the gas and turning to varnish. any local auto parts store or some major hardware store carry it.
