hokiruu wrote:I have the same situation too. I smell fuel after I get out of the car, but that could be because I don't have the charcoal canister connected right now.
I smell fuel in my car all the time. The ethanol, MTBE, god knows what mixture that we have out here smells kinda sweet. I like knowing that my car is running a bit rich.
With regards to StarfireS14's cold starts and high idle RPMs... What is a high idle RPM? 2000? 2500? 3000?!?! =)
When I first start mine, it floats up to 2K, then down to 1700. It gradually settles from there to about 1100 by the time the thermostat opens. That process takes 2-3 minutes. By the time I've driven for a couple of blocks, it settles to an 800 RPM idle when stopped.
Turbo charged cars are definitely more tempermental than NA's. Everything needs to come up to temp first. If you live in a cold climate, it takes longer to warm the fluids and expand the metal than it does in warmer climates.
I've noticed that when it gets closer to time to change the oil, it takes longer to settle down after first starting.
