tHe iLleSt RiCe »
https://forums.nicoclub.com/the-illest-rice-u50121.html
Sat Aug 09, 2008 9:36 pm
Whats up guys,
I replaced teh spark plugs on the VQ with some NGK v power plugs..When its cold outside, it will turn over and die immediately unless i give it a bit of gas, then it operates fine. I have never driven it at night prior to changing the spark plugs, so to be honest, i dont know if its a problem the cars had, or if it is new. I know the manuals say to use platinum ngk's but no one had them in stock, so i opted for the v powers. Has anyone heard of an issue with cold start problems after replacing plugs? It starts fine when the car has been sitting in the garage/outside. The problem doesnt come up until night time when the cars been outside and the temps drop. any suggestions on what to check?
Also, is it normal for it to idle at 500 rpm's in Drive and about 800 in neutral? Havent owned an automatic in a long while...thanks!
