ca18detgabby »
https://forums.nicoclub.com/ca18detgabby-u56657.html
Sat Feb 16, 2008 6:39 pm
could be a bad vac leak, could be an issue with the battery voltage when put under load, could be a coil pack(first guess after missing issue), or any number of other issues.
If I had to guess, I would start with the battery and couple that with a weak alternator, but idk....... it does start up as you say, but then falls off which could be a battery drained from a weak alternator that totally runs out and then cuts the engine......
but then agian idk, it is kind of hard to say without beig there.
