cold start SR problems
doctorj240
Car: Black s14 w/ redtop
Anyone have problems cold starting? On my first startup she only turned over once. Now she doesn't seem to want to start at all in the morning. It takes a while for her to catch after stumbling a while. And it's really rough, probably not too healthy for the engine. Any help would be greatly appreciated.
Jimmy
nismostate
Car: all sorts of motorsports
check your terminals? maybe a optima battery? just my 2 cents.
got2b240
Car: 91' RPS13 = GT28R, 525cc, Z32 Mafs & SAFC, Blitz EXST & FMIC, Silvia VLSD
i get that too on cold start, like it wants to die, once in a blue moon it does but since I redid my timing its gotten much better
NY S13 SR
Check your ECU temp sensor, the ECU can retard timing to help cold start and idle. Does your dash gauge read temp correctly? Also Idle Air Control Valve needs 12v power, check for that.
__________________Jeff Hheavythrottle.com
PSSHHGOESMYSR20
Car: 1991 Turbo Sentra SE-R
You may also want to check your O2 Sensor, a dead one tends to do that.
doctorj240 wrote:Anyone have problems cold starting? On my first startup she only turned over once. Now she doesn't seem to want to start at all in the morning. It takes a while for her to catch after stumbling a while. And it's really rough, probably not too healthy for the engine. Any help would be greatly appreciated.
Jimmy
doctorj240
I am running a electric water temp gauge. Could that have an effect on it?
