Cold start problem
BahamaMack
Car: 2005 nissan fuga
As of recently in the morning or when my 2005fuga sits for a few hours when it starts it has a stutter right before the engine rpm goes normal (for a cold start) .almost as if the car is struggling
Has anyone encounter this?
Ilya
Could be a lot of different issues...weak battery, failing spark plugs, other sensors, etc.
Do you have any check engine lights?
BahamaMack
Sparks plugs are new as of about 2 months
No check engine lights on
Battery is about a year n some old
Ilya
Could also be a pending code. Do you have access to an OBD-II reader? How many miles on the car?
BahamaMack
75000+miles
I have access to a reader
But as it is now there are no lights on the dash
BahamaMack
75000+miles
Ilya
Check it with the reader...a pending code won't trigger a light, but it'll be in the system as a fault code. Could give you a direction.
If you have no codes...I'd start with the basics such as checking that you have no vac leaks, etc. if all of the other stuff (like plugs) is good. If there is a leak, the MAF/TB might be trying to compensate, and hence rough idle at least initially.
