Make sure the orange wire is connected under the dash and has power when the key is in the START position. This activates a starting map in the ecu.mass90240sx wrote:any ideas. i was thinkin it is the orange starter signal wire...anything would be great thanks
I'm in Mass too. So if you want I can take a look at it and if I fix it you pay me and If I don't fix it you don't pay. If it's a quick find/fix you only pay me gas???mass90240sx wrote:yes i recently went through some of my wiring which was completely hacked by the previous owner and there was no power going to the orange ignition signal wire pin 34 going to my ecu so i rewired it and still nothing. also i did replace the battery and ran it to the back of my car and everyhting there is working just fine, when i try to start the car it just turns and turns until i finally just give up so i dont think that its my starter but ill check just in case. any other suggestions i shouold look at
during the cold start i don't gas it, but when it starts running i smell fuel, like if it were flooded.toyosmoke wrote:i'm having same problem, checked same and still the same. let us know what the problem was. thanks how can i check alternator
