Cold start: low idle then jumps up to normal 1800rpm
tjrob2000
Car: 2007 Infiniti G35 Journey sedan
'07 G35 Journey sedan.
The last 3 days the cold start is not normal. It starts fine, but the idle rpm's are in the 500 range for the first few seconds then come up to a normal 1800rpm before decreasing to 650rpm. No work has been recently done other than an oil change about 3 weeks ago. Car runs normally with good power when warm. Outside temp doesn't matter. Cranking speed sounds ok.
Tom
mdmellott
Car: '13 Kia Soul+ 2.0L AT
Your spark plugs could be getting worn out, maybe. TPS could be set wrong, maybe. Fuel pressure regulator may be going bad. I know, too many maybes. Hard to make a differential diagnosis without more symptoms.
tjrob2000
Spark plugs are brand new along with air filters. Forgot to mention this in my original post. I would expect a fuel pressure regulator to impact normal running as well which is not the case.
tjrob2000
This issue has gone away, possibly due to replacing the ground cable.
