black g50 wrote:Ok,it came back.Seems when I leave the seat heater switch to on,the next day battery is low.If heater switch off car starts and idles fine.Came out from work 5 in the morning and click! no start click click nothing.After a jump she cranked a few times before catching.I think it was told to me that they don't run when car is off,but seems mine do....Is there a fuse I can pull,don't really use heater that often as I wear a huge coat so cant really feel it anyway.
I'm 99 percent certain that the DC power to you seat heater is controlled by a relay.
The contacts on the relay are supposed to open when the ignition switch is turned off.
The fact that your seat heater continues to heat after the ignition switch is turned off implies that the contacts on the relay are sticking in the closed position, draining the battery overnight.
Suggestion: Find the relay, and temporarily unplug it. If your problem goes away, you need a new relay.
