The following is a list of things I've checked,
fuel pump pressureAAC valve, resistance, continuity (air regulator)IAC valve, played with adjusting screwCTSIAC, Air regulator connectorsfuses and fuel pump relaynew plugsnew injector sealsnew spark plug wires
good compression on all 4 cylinders
everything I've checked seems good
The car has a really rough cold start unless I play with the throttle it won't even start.But once the car is warmed up idle is fine and the car runs perfectly.
The only problem I'm having is the initial start up and I have no idea where else to check.
If anyone has any advice on where else and what to check it would help greatly.
THanks
