hmm, the o2 sensor can be had for about 30 bucks at any auto parts store, just ask for one from a de, but make sure they give you the one with 3 wires. autozone did that, so i went to advance and they seemed to have the right part.
did you see if the aacv was stuck? its a very common problem, mine was stuck so the car wouldnt run well at idle. i just took a screwdriver, some wd40 and some lithium grease to it and it works about 75% now, which is good enough for a smooth, 1200rpm idle when cold.
im not quite sure which air regulator you can use, might want to check both the ca18de and the ca18et. i know i had to get a new one, but it was so long ago that i dont remember which car i got it from. i would take it to an auto parts store and see if you can find a similar one. the old crossover thread is at
http://www.ca18det.org and you might be able to find it there.
sorry i was so useless yesterday. hopefully i wont do it again, haha
- tim
