CA18 RS13 »
https://forums.nicoclub.com/ca18-rs13-u1319.html
Tue May 27, 2003 12:10 pm
alrite, the air regulator is not supposed to suck air in after the car is already warmed up correct? I took off the hose and plugged up both ends and there was definate vacume periodically while idling. The thing is that even with the holes plugged, simulating what it it would be like if the air regulator valve was completely closed not letting any air by, my car still has that crazy idle. The weird part is that the harder i drive it the more normally it idles, but it degridates quickly. If i really get on it then let it idle, it will have a very strong and steady idle for a few minutes, then it will go into that thing where it goes 850-1300rpm or so over a few seconds time then drop back down to 850. If I let it sit long enough it eventually starts idling low and ruff, sometimes as low as 600's. So the AAC valve and the air regulator are both the same as the KA24DE's? I might as well replace both.
second question: I had accidentally been disconnecting the TPS when adjusting the idle screw and leaving the AAC plugged in (yeah im a dumbass), and just yesterday realized my mistake when looking over the FSM. Is there any way to reset it so that I can be sure the AAC is back to normal?
