sancem wrote:My neighborhood mechanic is not a trained Infiniti Technician nor espcially knowledgeable about the VH series. So what?!?
He is generally honest and competent and if he says he pulled the solenoid and tested it and it's not working, I believe him and I don't see why we should not replace it. I'll call Scottsdale and see if they can get me the part.
Well, I am pretty sure honest and competent mistakes cost just as much to repair as dishonest and incompetent mistakes.
If he knew what he was doing, he would first disassemble the IAC and clean it then check it. Can't recall the IAC solenoid ever failing on this board, but yours may be a first. When he R&R the IAC valve, also do the same for the EGR valve and TB and look at the plenum. You may then decide to go the whole 11 yards and pull it and do the hoses and KS.
Don't forget to have the gaskets on hand.
