sparkplugs.com »
https://forums.nicoclub.com/sparkplugs-com-u23266.html
Tue Dec 14, 2004 9:44 am
The manufacturers SHOULD recommend the correct stock plug for turbo applications. For every 75-100 hp you add in mods, you should go 1-step colder.
Stock heat range is 5. But if you've been running a 7, and its not too cold, i'd stick with it, don't go any hotter. For one step colder, NGK does still make the PFR6C-11, but not a 7.
Here's a list of the recommended 7 plugs:The two you already recommended:BKR7ES-11 (copper)BKR7EIX-11 (iridium)and BKR7E-11(V power copper)
