DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Sat Aug 06, 2016 11:25 am
That's great, glad you got her fixed!
Be sure to keep what I mentioned above in mind for the future as you most likely will have issues there, and with the other sensor/component connectors as well. The connectors are not weatherproof and after 26+ years will be brittle as well, and if it's a '93 or older the injectors will fail from ethanol and age which is a great time to do all connectors and harness as well as the newer style injectors.
Also be ready for PTU harness issues for the same reasons and location on front of engine, plus possibly the CAS connector. Nissan really did us NO favors with their hasty and ill-advised work with crappy engine connectors and redundant/excessive sensors.
