You have to consider the fact that if your car is parked outdoors and it's very cold then the amount of power required by the starter to start the engine is higher therefore requiring more amps. This also robs amps to other devices. The seat and steering wheel move at the moment you turn your car on. How does the slowness compare between fall and winter with the car simply being On without actually starting the engine? Then compare it to when you start. I can't see grease being an issue here unless you frequently wash the inside of your car.TDot wrote:Does anyone else have issues with auto seat and wheel adjustments when the car starts on cold days? I had the components changed out last year because I thought it was broken, but the same thing is happening again.
After putting it that way, I actually went out during lunch and disabled the steering wheel and seat movement when the door opens. I have no reason for it, but it did look so luxurious. I got used to it and step in/out was incredibly easy.msvara wrote:You have to consider the fact that if your car is parked outdoors and it's very cold then the amount of power required by the starter to start the engine is higher therefore requiring more amps. This also robs amps to other devices. The seat and steering wheel move at the moment you turn your car on. How does the slowness compare between fall and winter with the car simply being On without actually starting the engine? Then compare it to when you start. I can't see grease being an issue here unless you frequently wash the inside of your car.TDot wrote:Does anyone else have issues with auto seat and wheel adjustments when the car starts on cold days? I had the components changed out last year because I thought it was broken, but the same thing is happening again.
Just one more consideration. Different metals contract and expand at different rates when exposed to temperature differences so that could also be a contributing factor. Why have it on unless you are heavy set and need the clearance to enter/exit.
