Cold Pipe Question
emo
Car: s14b & gs300
Im stomped on what the piece that is sticking out on the cold pipe does check the picture out and help me please
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
zerothread?id=460576
This will answer your question.. and will cause you to have the same question I do.
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Blow-off valve?
motorboater
Car: nissan 240sx
iacv isnt it
Sleeper_RMS13
Car: 91 FB W/Blacktop SR
emo wrote:Im stomped on what the piece that is sticking out on the cold pipe does check the picture out and help me please
That nipple that your pointing too goes to the top right of your throtle body its the same place as your smic cold piping would go. But on this kit that nipple seems to be wielded on backward. It will still work bt since it would be backwords if that line ever kinked up you would be in trouble. So you pretty much you get what you pay for. And the littlest one goes to your watse gate and you can cap off that middle sized one you wont need that. And your going to have wield on a bov flange some were in your piping. Just a question...how much is this kit running? cause you can get a brand new greddy ls-spec fmic kit for 500 on frsport.com it will bolt right up but ud have to use your own hotpipe.
MR.chris
Car: 1995 Nissan 240sx se SR20DET Money Pit
Looks like it goes to the iacv.
emo
Car: s14b & gs300
i think it was made for a bov. The other vac line is for the iacv and a regular vac line. Sine i have a bov on my hot pipe i blocked it off and it worked just fine.
ray666
Car: '92 240 sr powered tuned with a neo
it goes to the iacv .you should put your bov on the hot side anyways.
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
Is it going to a redtop?If so Look right where the throttle body is there is a rubber vacuum line. It's about 6-8" line. That's where that elbow goes to.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Nah the 5/8"/16mm fitting on the cold pipe is for the IACV, I believe that big one is for the bov recirculation. Normally you see it on the hot pipe but on that set up its conspicuously absent.
I have seen bovs on cold and hot sides work just the same. However mounted on the cold side it has a cleaner look since the vacuum line isnt 6000 feet long.
duffman1278
Car: 89 240sx Hatch, the wildcats!
Recirculate
