S13FASTBACKSR »
https://forums.nicoclub.com/s13fastbacksr-u34823.html
Fri Sep 15, 2006 8:54 am
im curious to know if you guys are having any performance problems as well? if not then there is a part on your engine called the idle air regulator which is what causes your idle to be so high after a cold start...maybe ..just maybe this could be the problem but i doubt it as they do not go bad often and probably would cause a low cold idle if gone bad. check your ecu for codes that will help
