rjyentsch21 »
https://forums.nicoclub.com/rjyentsch21-u66044.html
Mon Nov 12, 2007 4:24 pm
Thanks for the tip. My transmission was at the low end of the dipstick, I filled it up but unfortunately it didn't help my problem. Not sure if it's related or not but around the same time the cold performance problems started my cruise control began acting up, sometimes it would work and sometimes it wouldn't. Hooked up to the OBDII system and got an error code showing the vehicle speed sensor malfunctioning. My speedo seems to be working fine, as well as the rest of my gauges. Getting a little fed up, all this is on a vehicle with less than 30k on it, I thought Nissan was supposed to be good.
