DrJuice164 »
https://forums.nicoclub.com/drjuice164-u29229.html
Sat Apr 11, 2009 1:38 pm
Just got back from looking at a redtop and the only test we were able to do is compression. The starter is frozen so we couldn't do it that way; so we turned the crank bolt instead. The motor has been sitting for a while and we got 80 80 110 70 compression. I am not sure if these are good results as the motor was cold and was turning by hand. We did add a drop of oil to cyl 4 and it bounced from 70 to 85ish. Can anyone comment on if these are decent results or is the motor weak.
Thanks,
Bryan
