roundrocktom »
https://forums.nicoclub.com/roundrocktom-u6673.html
Wed Jul 16, 2003 6:13 am
Go ahead and check the compression with the cold engine, as this will still give you a pretty good idea of ring and valve condition.
You will discover the compression readings are down a little, but compare all the cylinders to each other.
Typically I've found COLD compression checks to show the start of a blown head gasket (once warmed up, everything was fine for a few months until the gasket blew).
Valves needing adjustment might show leakage at hot, but fine at cold. Burned valves will leak, regardless of hot or cold!
Piston slap is more noticeable at cold temp. Oddly the only time I ever hear it is a on Chevy Vortec 6.0 (2500HD tow vehicle) first start in the morning.
Remember to do a dry/wet readings. Just add less than a teaspoon of oil to the cylinder, THEN crank about a half dozen times (most excess oil is pushed out the open spark plug hole, THEN take the compression reading. With a cold engine you'll probably notice more of an improvement with oil, but once again you want to compare all the reading to each other to see if there is a problem. Usually as I am about to test cylinder #6 dry, having completed 1-5, I'll squirt the oil into #1 to check after I do #6... so on. That fine mist of oil is flammable, so use care with any spark!
If you are inspecting an engine to buy, pull off the valve cover and take a look! With proper oil changes everything should look almost new, just a light coat of "light brown" shellac is normal.
Good luck!
Tom
