cold clutch
neongreenglo
Car: 90 240sx fastback
i believe that my car has a cold cluth meanin in cold weather the seal contract and i loose a little fluid i'm not possitive i did notice that when its cold my car wont hardly go into gear at all i have to pump the clutch a few times then it slides in perfect .... it might be due to air in the lines also ... where is the slave cylinder so i can bleed my clutch i have no clue
s13sr20chris
slave cyl is on the pass side of the transmission. give her a good bleed and check the gear oil in the trans too. sometimes cold gear oil has a hard time going into gear.
