Cold Blooded RB20
rb20detsilvia
Car: 92 nissan 240sx
When My Car Is Cold It Seems To Be Cold Blooded And Want To Die The Idle Dosent Stay Up Like If you Have A Choke Any Ideas
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
Did you wire the orange wire? Its like a choke. My engine didnt want to start or stay running when cold until I wired it up. I have a post about it on racebread.com
Joe
Vkoslak wrote:Did you wire the orange wire? Its like a choke. My engine didnt want to start or stay running when cold until I wired it up. I have a post about it on racebread.com
or you could just give that info here?
im kinda getting tired of the fishing for new members from over there.
rb20detsilvia
What Orange Wire And Where Do i Wire It Please Post On this Forum
Vkoslak
Sorry, I wasn't trying to fish.
here is what I had:
That orange wire is important! The ecu register for "ignition start" does not click to "on" if you don't have this wired up. Before my car took several attempts to start before it would run when cold. Now it starts right up. I think it is telling the fuel pump to pressurize the lines.
Which was followed by:
Jon Powell - Ever hear of a choke on an older carbeurated motor?
Orange wire is your choke.
Other info:
in the 240sx FSM wiring diagram, I think I found the connector I am talking about labeled as "F1" on ECU side and "M53" on harness side.Orange goes to the "Ignition Switch On or Start"
Goes to pin 43 on the rb ecu plug.
This helped me a lot (the rb side anyhow)http://s92978298.onlinehome.us/RB/gtr_plugs.pdf
connector "P" in the diagram pin "b". Diagram says its black and yellow.I just spliced the orange wire into this wire. I didn't have to do anything down by the ecu.
Hope that helps.
Joe
thank you Vkoslak
armysweitzer
Car: RB20DET S13
lol my car wouldnt start either till i talked to jon about this same issue he had me running in under 10 minutes.
I vote jon powell MVP of rbs...
Valley
Car: 00 celica gt-s 89 240sx hatch
Vkoslak wrote:That orange wire is important! The ecu register for "ignition start" does not click to "on" if you don't have this wired up. Before my car took several attempts to start before it would run when cold. Now it starts right up. I think it is telling the fuel pump to pressurize the lines.
you mean its what primes the fuel pump (turns it on before actual cranking to pressurize the system) ? if so, it priming, not choking, very different. if i have my car parts right its the iac thats the choke.
Vkoslak
From what i remember on the wiring diagram, they all run together anyhow, so if your prime isnt working, your choke aint working either. But I could be remembering wrong and I am too lazy to go look it up.
rb20detsilvia
I Can Hear My Fuel Pump Turn On When The Key Is On Just When Its Cold It Will Idel Down And Die It Dosent Stay At Like 1500RPMs Like My Other Cars Ive Owned And I Have To Press The Gas Pedal To Get It To Fire Up When Im Cranking
wawazat8402
Car: 89 Sil80- RB25DET
It richens up the fuel map when it knows you are starting it. The pump prime is independent of this wire as is IAC. Its just like a choke on a carbureted engine except it is telling the ecu to pump more fuel through the injectors.
Bluefire
Wow I thought the start signal wire was like one of the cardinal wires that get hooked up... Anyways you might also want to make sure that your air regulator is hooked up also. This will raise your idle up for a minute or so when you first start your car.
