RicerX »
https://forums.nicoclub.com/ricerx-u125542.html
Mon Jul 08, 2013 10:39 am
Not all intakes are created equal. Piping design is just as important as the filter as far as an aftermarket intake is concerned. You want piping that is optimized for that car, so piping diameter cannot be too small or too large. The more bends in the pipe will cause more turbulent airflow, which robs you of power. Piping material such as thin billet aluminum will also absorb more heat than say titanium (but many of us cannot afford that), which leads me to my next point.
Heat is the enemy of air intake setups, which is why a true cold air setup is what many people pursue, but the Altima 3.5 does not have that option, as the Altima's engine bay design is not conducive to a true "cold-air" setup. It has to grab air from inside the engine bay, which is hot and heat soak reduces power.
There are several aftermarket intakes available for the Altima 3.5. The best performing ones are ones with heat-shielding around the filter assembly. The two I have experience with are AEM and R2C. The AEM is more intensive as far as installation goes. The R2C is easier to install.
I haven't seen the K&N intake setup for this car and I cannot recall if it has any heat shielding. If it does, it's a good option. If it does not, then it's not the best. Filtration will be just fine, but there won't be much there for power gains, if any.
