Cold Air Intake
Khronik
Car: Pearl White - 91 N/A 2+2 Auto (RIP)
Arctic White - 96 N/A 2+0 5spd (SOLD)
Aztec Red - 90 TT 2+0 5spd (DD)
- Megan Racing DP's
- Borla Catback exhaust
- CZP ECU Upgrade
- SZ High 5 Clutch
Alright so the previous owner apparently installed Injen pipes with cold air intake..
you know those fancy intake pipes that most people dont recommend installing on anything other than a TT..
Well it looks like the drivers side has the cold air tube&filter under the car and he wrapped it in tape.. :nono:
The passenger side looks like it may or may not have had the same setup, either way as it sits right now that tube was either designed to be closed or was melted closed. basically a stub sittin there.
Im not too familiar with cold air, but im assuming if water gets into that cold air filter and into the intake system it can potentially kill the engine for good?
Is the filter being taped killing performance at all?
Would it be best to close this tube, removing the cold air, like on the passenger side?
Or remove the tape from the cold air filter when weather permits and retape when it does not?
NissanFairladyZ32
Car: 91, Twin Turbo, 99 Miata 1.8L
post a picture up
es.biggs
Car: 1990 300ZX 5sp NA
That makes no sense man. I 2nd the motion for pictures lol
Khronik
- Megan Racing DP's
- CZP ECU Upgrade
- SZ High 5 Clutch
thatd prob be easier ill take some pics when I get off work
seems like it has a bottom-feeder intake (the mentioned taped driver side filter under the car), and the usual intake at the T-section under the nose panel
Khronik
- Megan Racing DP's
- CZP ECU Upgrade
- SZ High 5 Clutch
Heres whats under the drivers side..
Starting from the top
and the tape..
Now heres whats on the passengers side, as you can tell its sealed closed.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
II'm not sure what that it, might be some sort of factory silenecer ont he n/a? fwiw all 74-96 z cars are cold air form the factory, thye just use normak filters not fancy cones
Khronik
- Megan Racing DP's
- CZP ECU Upgrade
- SZ High 5 Clutch
anyway to remove it? doesnt seem like its doing anything since the passenger side is sealed and drivers taped
evildky
06 Nissan 350Z GT
looks liek ti goes inline between the afm and the tb's so youst take them off and plug the holed, or get that hard [pipe fomr a TT which does nto have that drop on it
Zero to 300
Car: 90 300zx N/A to TT
What i did during my NA to TT conversion was remove those pipes capping the ends and removing the fender boxes, car runs fine no problems. Just remove the rings and pipes coming off the bottom of the big t-pipe your MAF plugs into and close em up with either welding a plate on them or sealing the hole with some rubber sheets or something that does NOT allow air in or out of the pipe.
